Hello everyone,
how is it possible to use the 'Use Criteria' entry in Geospatial Connector Admins Feature property definition? For Explanation look at that:
The Domain List behind is the following:
What I try to achieve is to filter the Domain List entries for the specific Feature through the 3rd column value. I'm using that Domain List for several Features - in each are displayed other values.
Is that possible or what is the 'Use Criteria' entry for? And how would the Syntax look like?
TIA,
Maik
Sebastien Cote
Answer Verified By: Maik Schulze
Hello Sebastien,
these are very good examples, thanks for the suggestion. What I was trying to achieve is to filter the domain list based on a static value not another property. For instance: show all value1 where value3 is 'ATKIS_VEG_F'. I thought I could use the criteria entry like shown here:
But I realized how to use the criteria by the help of the geo_example. I wanted to use one domain list (with filters) for all my features, but I better create several domain lists to get to the desired result.
Thank you,
Hello Maik and Sebastien,
Did you manage to get a solution? I don't see it here. I too want to filter the domain list dropdown by one column in the domain list and not by a filter on another feature property.
Tanya
Hi Tanya,
I couldn't manage to filter by that criteria as I wanted and I split the Domain into several single Domain lists, as I had no time to do try and error. The example in my last screenshot didn't work.
If you are able to get it configured as you desired, please let us know here
Regards,Maik
