Define criteria-based DomainList in Geospatial Admin
Hello everyone,
how is it possible to use the 'Use Criteria' entry in Geospatial Connector Admins Feature property definition? For Explanation look at that:
The Domain List behind is the following:
What I try to achieve is to filter the Domain List entries for the specific Feature through the 3rd column value. I'm using that Domain List for several Features - in each are displayed other values.
Is that possible or what is the 'Use Criteria' entry for? And how would the Syntax look like?
TIA,
Maik
  • Hello Mladen,
    RE: For the first part of your answer I have one more quick question. In your GSA project you have two connections. First is connection to graphical source (in your case SQL Server I quess) and second is ODBC connection that you use for non spatial tables (domains) with SQL statement. I'm I right?
    Yes the ODBC is for my SQL statements that appear in the SQL domain dropdown. Without this my dropdowns for the SQL queries do not appear. The second is for my spatial features.
    Kind Regards,
    <![if !vml]> <![endif]>
    TANYA GELDENHUYS
    Senior Consultant
    T +27 12 345 5330
    M +27 72 762 2450
    www.theiglobegroup.com
