Hello all,
Got this error message when attempting to connect the Oracle Spatial connection via spatial tools connections in Bentley Map.
This is quite weird to me because I used to do this before without any error: but recently this error occurred while on the other hand i have no problem with Oracle Spatial connection in Bentley Geospatial Administrator register features.
Anyone has experience the same? Please share your thoughts and expertise.
Jun
Juns,
So you can properly register your features within Bentley Geospatial Administrator. Is that right ?
Once done, you run your workspace and then try to connect thru your registered connection (see screen shot) and it fails. Is that right ?
Sebastien Cote
