Crash Visual Query Builder 10.00.00.25
Workflow:
  • Attach
  • Connect
  • Connect to database: oracle
  • Visual Query Builder
  • Tables: select mscatalog
  • Table Mscatalog: select entyitynum
  • SQL select statement is now: SELECT ENTITYNUM FROM MSCATALOG
  • Execute and MicroStation crashes
Any suggestions?
  • We would need to know more about the operating environment in order to make helpful suggestions. Did this work using V8i software? Does it work on other PC's running MicroStation CONNECT? Did you collect the crash dump file that you can send to the Support Group?
  • I would add:
    - explicit version and connection details, e.g.
    --OS (+bit depth)
    --MS version
    --connection type (ODBC, Oracle, Xbase…)
    -- Oracle server details (e.g. Oracle Enterprise 08.09.10.11) (+bit depth)
    -- Oracle client/connection details (Oracle RSF version, ODBC version,...) (+bit depth)
    The quick cursory test: does executing the same SQL from the SQL window cause a crash or error?
    What toggles are engaged within the VSQL builder at the time of submission?
    Depending on the crash event (or during testing using SQL window), a second look might be obtained by using the session debug option to record the event:
    MicroStation Keyins:
    DMSG OPENMSGFILE c:\yourfile.txt
    SESSION DEBUG ON
    -- (perform action) --
    SESSION DEBUG OFF
    DMSG CLOSEMSGFILE
    ...review yourfile.txt
    Ultimately, this could be data based (SQL reserved words or characters, duplicate mslink), so details regarding the MSCATALOG table structure may be necessary.
    As it is Oracle, do note case sensitivity verbatim.
  • Hello Kees,
    Since MicroStation CONNECT Edtion is a 64-bit application, did you install the Oracle Client 64-bit on your Workstation ?
    Sebastien Cote
  • Hello Dan, Nelson and Sebastien,
    ExceptionHistory-1.zip
    MicroStation Connect 10.00.00.25 and MicroStation V8i 08.11.09.357 are installed on the same PC.
    10.00.00.25 uses an Oracle11GClient64
    08.11.09.357 uses an 32-bits-client
    The Oracle-server is: Oracle Database 10g Enterprise Edition Release 10.2.0.5.0 – Production
    Connecting to the database and querying both using mdlDB-functions is no problem in Connect and V8i
    Only using SQL and VSQL is no problem in V8i
    Using SQL “select * from mscatalog” is a problem in Connect (see also dmsg_sql.txt):
    • only the first 3 columns are visible: the scrollbar doesn’t work.
    • the records are dimmed.
      Using VSQL “select * from mscatalog” is a problem in Connect (see also dmsg_vsql.txt + exception.log + minidump.dmp).
      The describe and data of the mscatalog-table:
      SQL*Plus: Release 11.2.0.3.0 Production on Thu Oct 15 11:52:26 2015
      Copyright (c) 1982, 2011, Oracle. All rights reserved.
      Connected to:
      Oracle Database 10g Enterprise Edition Release 10.2.0.5.0 - Production
      With the Partitioning, OLAP, Data Mining and Real Application Testing options
      Name                                                    Null?   Type
      TABLENAME                                           NOT NULL CHAR(32)
      ENTITYNUM                                           NOT NULL NUMBER
      SCREENFORM                                                     CHAR(64)
      REPORTTABLE                                                   CHAR(32)
      DASTABLE                                                         CHAR(32)
      SQLREVIEW                                                       CHAR(240)
      FENCEFILTER                                                     CHAR(240)
      FORMTABLE                                                       CHAR(64)
      TABLENAME                              ENTITYNUM
      nag_panden                                     2001
      nag_vw_panden_gisnr                      2002
      nag_verblijfsobjecten                       2003
      nag_vw_verblijfsobjecten_gisnr         2004
      nag_ligplaatsen                                2005
      nag_vw_ligplaatsen_gisnr                 2006
      nag_standplaatsen                           2007
      nag_vw_standplaatsen_gisnr             2008
      nag_woonplaatsen                           2009
      nag_vw_woonplaatsen_gisnr             2010
