Dear all,
I am using Bentley Map v8i series 3. I need to Export the Dgn file to Shape File with attributes. I did the conversion using Export option but attribute is not showing in the shape file i dont know where i am make the mistake please any help me for this conversion.
Note:
Here i attached the Sample Dgn.CHLSTGO_BUILDINGS_2D.dgn
Which Export option did you select? If you use Add Shapefile, then you must choose the "Building" feature to export. The CHLSTGO_BUILDINGS_2D features do not contain any attributes, except for the system-generated geometric properties for area and perimeter.
