Hello.
Does Bentley Map Mobile support polygon transparency?
Regards, Bjorn
Bjorn,
The current Bentley Map Mobile Publisher process uses the actual element symbology that can be set with the feature class definition in the Bentley Geospatial Administrator or through the use of MicroStation tools such as Change Element or Element Information.
Future Bentley Map Mobile Publisher enhancements are planned that will publish element symbology defined "dynamically" with the Map Manager in Bentley Map or Level Symbology in MicroStation.
Jeff Bielefeld [Bentley]
