Hi
We use to install Bentley map without the user needs to interact, but now we are going to roll out built 633 of Bentley map SS4 and the normal installation using the setup.exe with options /Qrui now stops at the end and needs button "Finish" to be pressed before installation is terminated and the setup script can continue.
Are there and extra option that needs to be set to make the installation finish like it use to do ?
We have to roll out on 200 workstations over the weekend, so help will be vary appreciated
Erik Wirring
LE34
Denmark
Erik, I always see a Finish button at the end. Do you mean now you see an additional one? Which Bentley Map edition used here? Standalone? Enterprise? Have you try with .msi file? Sorry for questioning, I try to narrow down the behavior you described and I do not reproduce.
Thank you and regards, Sebastien Lefrancois [Bentley]
