Hello.
I added a watcher list to a certain property (LandStatus) and now I'm unable to edit data in the DataBrowser for that single property. In the "Edit XFM Feature" dialog it works fine though but I would like to be able to edit data in the DataBrowser as well.
Is that normal behaviour in Bentley Map that when a watcher list is added the property becomes a "read-only" in DataBrowser?
I'm using Bentley Map (SELECTseries 4) verson 08.11.09.503 for MicroStation.
Bjorn Magnus
Stod ehf.
Hello Bjorn, Yes. Unfortunately, the properties defied by watcher are read-only in Data Browser. The only way to edit these values is to use the Edit XFM Feature tool. Regards, Sebastien Lefrancois [Bentley]
Answer Verified By: Bjorn Magnus Arnason
Unknown said:Are there any plans on making this function available in DataBrowser?
Hello Bjorn,
I do not have the inside track. I am not aware of any plan to implement this in early future. Be sure I will report your request to internal instances. Sorry for the inconvenient and thank you to sharing your experience with our product.
