How to add rotation to Cells when importing SHP files
I'm not sure if this is the right place for this topic,,but here goes
I am importing a shp file (points) as cells,  that have rotation values included in the attributes.  How can I rotate the cells to those values other than using element information and changing the cell angle to the rotation value manually for each one?
