I haven't seen any mention of this on the forum, so I'll ask...
Will there be a Bentley Map Technology Preview (or Beta) for the CONNECT Edition similar to what we had for MicroStation CONNECT and Bentley Map SS4?
If so, when is that expected to happen?
In working with MicroStation CONNECT workspaces and the changes to the user configuration level I would imagine that this will require a substantial change in how Bentley Map workspaces are set up. I would also like to start planning for any XFM feature migration required from Map SS4 to Map CONNECT.
Thanks.
Unknown said:At least some insights what we could expect from Bentley Map CONNECT. It will be just a port to Microstation CE with migrated old and introduced new bugs or major update?
It's exactly the information that were shared in disucssions for some other products and despite of because of time and software development constraints not always were reached fully or had to be changed, they have helped user to make preliminary decisions and plans. It's very usefull e.g. when budget and resources are planned annually.
Jan
