Hello Bentley
Something strange happens when upgrading Bentley Map SS4 to built 666 !
All the standard tasks in the task menu are missing. In the Entreprise version the task menu looks like this:
And if we set the config variable MS_GEOSURVEY_TECH to 1, the task menus for civil tools do not appears !
Furthermore it looks like 'Bentley MapStandalone SS4 built 666' do not reinstall civiltools, while 'Bentley MapEntreprise SS4built 666' do install "CivilPlatform" under "Common Files/Bentley Shared", or at least do not remove them.
Is it just us? or can we expect a new set of installations packages for 'BMap SS4 upgrade 2' or a add on installation package ?
Best regards
Erik Wirring
Landinspektørfirmaet LE34
Denmark
