We find Go to X,Y tool in ArcMap. So, do we have the similar tool in Bentley Map? So, we can type x and y coordinates and can zoom to / pan to that location. I looked in the documentation but could find any tool. We have X,Y in AccuDraw but that is used while drawing new feature. Any help is appreciated.
Kiran.
Accudraw must be enable ;-)
you can clic on the toolbar x,y,z or Distance and angle before, and after hit "p". This is a shortcup of Accudraw.
Fabrice
Hi Fabrice,
I got it to open, I pressed F11 key. Thank you for your tip.
However, this opens only in the context for placement tool like Active Points etc. Does the Bentley Map have only Go to X,Y functionality that can be invoked irrespective of you are drawing anything or not.
Thank you in advance,
