[BM SS4] Registered SQL*Server Feature has no Text Sub-Feature
I've got a table in SQL*Server intended to store polygon information. When I "register features", I set the feature to be a polygon-collection, and in the GSA I see the resultant "MyPolygon_Collection" and the sub-feature "MyPolygon". I can't figure out how to get a second sub-feature of the collection for "MyPolygon_CollectionText". When I right-click and "insert polygon placement metadata", there is no bottom section for the annotation modes....And the sub-feature only show "Schema Versioning" for the right-click operations. Is annotation not possible for "collections"?
  • Bruce,
    You will need to have a related table which contains locations of annotation sub-features. For example you might have...
    CREATE TABLE BUILDINGS2
    	[ID] [int] IDENTITY(1,1) NOT NULL,
    	[CONSTRUCTED] [date] NULL,
    	[VALUE] [int] NULL,
    	[NAME] [varchar](50) NULL,
    	[CLASSIFICATION] [int] NULL,
    	GEOM geometry NULL
    ...to create the polygon table, then for the annotation text table...
    CREATE TABLE BUILDING_TEXT
    	(TEXT_ID INT IDENTITY (1,1) CONSTRAINT BUILDINGTEXT_PK PRIMARY KEY,
    	BUILDING_REF INT CONSTRAINT ST_FK REFERENCES BUILDINGS2(ID) ON DELETE CASCADE,
    	MS_ANGLE REAL,
    	MS_XSCALE REAL,
    	MS_YSCALE REAL,
    	GEOM GEOMETRY);
    ...which when registered in the Bentley Geospatial Administrator yield the following:
    Attached is a sample SQL script which demonstrates how a polygon table with annotation text table can be created.
    USE [sample1]
    GO
    IF OBJECT_ID ( 'dbo.BUILDING_TEXT', 'U' ) IS NOT NULL
        DROP TABLE dbo.BUILDING_TEXT;
    GO
    IF OBJECT_ID ( 'dbo.BUILDINGS2', 'U' ) IS NOT NULL
        DROP TABLE dbo.BUILDINGS2;
    GO
    IF OBJECT_ID ( 'dbo.CLASSIFICATIONS', 'U' ) IS NOT NULL
        DROP TABLE dbo.CLASSIFICATIONS;
    GO
    CREATE TABLE CLASSIFICATIONS
    	ID int NOT NULL,
    ALTER TABLE CLASSIFICATIONS
    	WITH CHECK
    	ADD CONSTRAINT CLASSIFICATIONS_PK
    	PRIMARY KEY(ID);
    GO
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (1, 'CLASSIFICATION 1');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (2, 'CLASSIFICATION 2');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (3, 'CLASSIFICATION 3');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (4, 'CLASSIFICATION 4');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (5, 'CLASSIFICATION 5');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (6, 'CLASSIFICATION 6');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (7, 'CLASSIFICATION 7');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (8, 'CLASSIFICATION 8');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (9, 'CLASSIFICATION 9');
    INSERT INTO CLASSIFICATIONS (ID, NAME) VALUES (10, 'CLASSIFICATION 10');
    GO
    	[VALUE] [int] NULL,
    	GEOM geometry NULL
    GO
    INSERT INTO BUILDINGS2 (NAME, VALUE, CLASSIFICATION, GEOM) VALUES ('BUILDING 1', 930264, 1, geometry::STGeomFromText('POLYGON ((-90 285, 9 285, 9 385, -90 385, -90 285))', 0));
    INSERT INTO BUILDINGS2 (NAME, VALUE, CLASSIFICATION, GEOM) VALUES ('BUILDING 2', 829498, 2, geometry::STGeomFromText('POLYGON ((97 114, 197 114, 197 214, 97 214, 97 114))', 0));
    INSERT INTO BUILDINGS2 (NAME, VALUE, CLASSIFICATION, GEOM) VALUES ('BUILDING 3', 51898, 1,  geometry::STGeomFromText('POLYGON ((101 -233, 201 -233, 201 -133, 101 -133, 101 -233))', 0));
    INSERT INTO BUILDINGS2 (NAME, VALUE, CLASSIFICATION, GEOM) VALUES ('BUILDING 4', 984885, 7, geometry::STGeomFromText('POLYGON ((612 -173, 712 -173, 712 -73, 612 -73, 612 -173))', 0));
    INSERT INTO BUILDINGS2 (NAME, VALUE, CLASSIFICATION, GEOM) VALUES ('BUILDING 5', 681766, 6, geometry::STGeomFromText('POLYGON ((500 0, 600 0, 600 100, 500 100, 500 0))', 0));
    GO
    ALTER TABLE BUILDINGS2
    	WITH CHECK
    	ADD CONSTRAINT BUILDINGS2_PK
    	PRIMARY KEY(ID)
    GO
    	WITH CHECK
    	ADD CONSTRAINT BUILDINGS2_FK
    	FOREIGN KEY (CLASSIFICATION)
    	REFERENCES CLASSIFICATIONS(ID)
    GO
    CREATE SPATIAL INDEX BUILDINGS2_SPX
    	ON BUILDINGS2(GEOM)
    	WITH ( BOUNDING_BOX = ( 0.0, 0.0, 5000.0, 5000.0 ) );
    GO
    -- The following code will fill the StartDate column of the FiscalYear table with random dates between two given dates:
    -- First, let's declare the date range.
    DECLARE @date_from DATETIME;
    DECLARE @date_to DATETIME;
    -- Set the start and date dates. In this case, we are using
    -- the month of october, 2006.
    SET @date_from = '1985-10-14';
    SET @date_to = '2009-04-27';
    UPDATE BUILDINGS2 SET CONSTRUCTED =
        -- Remember, we want to add a random number to the
        -- start date. In SQL we can add days (as integers)
        -- to a date to increase the actually date/time
        -- object value.
        @date_from +
        	-- This will force our random number to be >= 0.
        	ABS
        		-- This will give us a HUGE random number that
        		-- might be negative or positive.
        		CAST(CAST(NewID() AS BINARY(8)) AS INT)
        	-- Our random number might be HUGE. We can't have
        	-- exceed the date range that we are given.
        	-- Therefore, we have to take the modulus of the
        	-- date range difference. This will give us between
        	-- zero and one less than the date range.
        	-- To get the number of days in the date range, we
        	-- can simply substrate the start date from the
        	-- end date. At this point though, we have to cast
        	-- to INT as SQL will not make any automatic
        	-- conversions for us.
        	CAST((@date_to - @date_from) AS INT)
    GO
    -- CREATE BUILDING TEXT ANNOTATION TABLE
    	MS_ANGLE REAL,
    	MS_XSCALE REAL,
    	MS_YSCALE REAL,
    	GEOM GEOMETRY);
    GO
    INSERT INTO BUILDING_TEXT (BUILDING_REF, GEOM) VALUES (1, geometry::STGeomFromText('POINT (32 354)', 0));
    INSERT INTO BUILDING_TEXT (BUILDING_REF, GEOM) VALUES (2, geometry::STGeomFromText('POINT (213 182)', 0));
    INSERT INTO BUILDING_TEXT (BUILDING_REF, GEOM) VALUES (3, geometry::STGeomFromText('POINT (58 -246)', 0));
    INSERT INTO BUILDING_TEXT (BUILDING_REF, GEOM) VALUES (4, geometry::STGeomFromText('POINT (333 -106)', 0));
    INSERT INTO BUILDING_TEXT (BUILDING_REF, GEOM) VALUES (5, geometry::STGeomFromText('POINT (221 50)', 0));
    GO
    -- CREATE SPATIAL INDEX
    CREATE SPATIAL INDEX BUILDINGTEXTSDX
    	ON BUILDING_TEXT(GEOM)
    GO
    Jeff Bielefeld [Bentley]
  • Thanks - now that you mention "related tables", I went back to the Help file and found the information. Most of it was listed under "Oracle Spatial", which I skipped as I'm using SQL*Server. Thanks for the "pointer". I'm seeing other issues related to creating XFM features for a polygon-collection table from SQL*Server (i.e. methods, operations, and command manager), and as soon as I get those sorted out, I'll give this a try.
  • After "correcting" the column names of my text able from MS_XSCALE and MS_YSCALE to MS_X_SCALE and MS_Y_SCALE, after re-registering the spatial feature, now I *do* see Annotation Options as part of the Insert Polygon Placement Metadata. However, I only see "View" and "Rotated" toggles...
  • What version of Bentley Map are you using? Do you observe the same behavior if you first "Delete" the feature class definition before performing the "Register Features..." process? Could you send me via private message a copy of the Bentley Geospatial Administrator XML schema for review?
  • Using Map Enterprise 08.11.09.666. I have been first "deleting" the feature in GSA, then "Save"ing the results. Without exiting, I right-click on the spatial connection and "Register features".
  • Bruce,
    I contacted one of my colleagues familiar with the "Insert > Polygon Placement Metadata..." process in the Bentley Geospatial Administrator and was able to determine that the "Align" annotation option is not available for polygon collection feature classes. I reviewed your schema and see one simple polygon feature class and another polygon collection feature class. If you attempt the "Insert > Polygon Placement Metadata..." process on the simple polygon feature class you should see the "Align" annotation option.
    As you probably know and seen in the following, during the "Register Features..." process you can select the "Feature Type" choosing either "Polygon" or "Polygon Collection" depending on your needs.
  • Thanks for the update. The polygon collection is the only one we are interested in currently.
Reply Children
