I have few Oracle Spatial tables added to my Bentley Map (v 8i Select Series 4). How can I set the minimum and maximum scales for a layer to be visible in the Map Manager?
When I right click a layer, select properties, I see a dialog box. This has only two tabs, General and Extent. The screen shot for the same is pasted below. I could not find anything regarding scale setting.
Any help is appreciated.
Kiran.
Kiran,
In the Map Manager you can perform the following:
If you prefer to define default visible scale ranges for each of your feature class definitions as part of your schema, in the "Features" tab of the Bentley Geospatial Administrator you can set "Min Zoom" and "Max Zoom" values (as shown below for "building" feature class), then "Save", "Export" and "Run" your updated workspace.
Jeff Bielefeld [Bentley]
