We are using Bentley Map and data from Oracle Spatial.
In out certain workflows, we do not want some of the users to edit data in Bentley Map and grant them Read Only access, so we are trying to hide Command Manager panel in the Bentley Map.I tried to achieve this in Geospatial Administrator by not adding anything to the User Workspace -> User Interface -> Command Manager (Command Manager node in the workspace was empty). However, even after doing this, when this user workspace is selected while opening Bentley Map, the Command Manager is still visible.
Can anybody shed some light on this? Appreciate any help.
Cheers,
Kiran.
Answer Verified By: Dan Weston
