Hi everybody.
I´m new with Bentley map, So there are many things which I dont know.
Fist thing I wanna do, is to edit an shapeFile or geodatabase.The steps I´m following are:
1-Open Microstation V8i, (ss3)User: geo_example_designerProject Map FinishingInterface: None2-Create a map. FIle - Map Manager3-Atach shapefile.4-Right click in shapefile layer, and select "make active for editing"
But this doesnt work.So I supose that I forgot something.
Other option I tried.
File -> Open Oracle Spatial.Connections -> new Esri geodatabase connection.
But I don´t know how to display this on the screen, either modify this.
In addition I saw other tool in webinars Where they use "Open graphical source NASH". But this option does not appear
Anyone know how to edit a shapefile or gdb in Bentley Map ?
The target is, use the same shapefiles or GDB between Arcgis and Microstation (map, inroads...) in order to avoid copies.
I will appreciate any comment.
Lucas.
Hi Lucas,
Unknown said:there are many things which I dont know.
Bentley Map is very versatile product, but at the same time I have to say it's a bit "user agressive" (as opposite to "user friendly") in some features and it's not always clear for the first sight how it works and what and how should be configured.
Unknown said:Fist thing I wanna do, is to edit an shapeFile or geodatabase.
It's not possible to edit SHP file directly, but you can import it into DGN, add, modify and remove content, and to export it back to SHP in a managed way using XFM project.
ESRI Geodatabase can be edited directly in two different ways:
The way how support of spatial data sources (Oracle, SQL Server Spatial, ESRI GDB) is implemented in Bentley Map is similar to other GIS software:
To query and post the data, Data interoperability dialog should be used. Map Manager is not required at this scenario.
With regards,
Jan
