every time i try this i seem to struggle,, i have a dgn with some closed shape in it, i need to convert to SHP files
i deploy "map" and get the Interoperability tool to fire up (which is not very intuitive btw) I hit "export" new it shows two layers,
the two i want to convert to SHPs,.,, It appears works but only for a few shapes , despite using Fence and all options , not sure if i am missing a step, i right click export both layers?
i reference it in the shape file to check it , fall into place but like i mentioned before i dont get all the data?
Answer Verified By: Sebastien.Lefrancois
