Building Schema from Existing XFM files.
Is it possible to generate the feature definitions from an existing XFM DGN?
 If I import a MapInfo TAB into a DGN, it will generate the XFM attributes.  But can I import these features (either from the DGN or MapInfo TAB file) into the Geospatial Administrator to simplify the generation of the features (and simplify changing products).
 Regards Ian
Parents Reply Children
