We have several .gdb files/databases that seem impossible to import or connect to (import tab and connections tab) in Bentley Map.
I am receiving the following error in the Map Interoperability tool:
Exception: Item has already been added. Key in dictionary: 'Seabed_Feature_Arc' Key being added: 'Seabed_Feature_Arc'System.ArgumentException: Item has already been added. Key in dictionary: 'Seabed_Feature_Arc' Key being added: 'Seabed_Feature_Arc' at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add) at System.Collections.Hashtable.Add(Object key, Object value) at Bentley.EngineeringContent.Storage.ObjectToRelationalStorage.ECSchemaUpdater.InitTables(IECSchemaObjectId[] allowedSchemaObjects) at Bentley.EngineeringContent.Storage.ObjectToRelationalStorage.ECSchemaUpdater.Update(IECSchema schema, IECSchemaObjectId[] allowedSchemaObjects) at Bentley.EngineeringContent.Storage.ObjectToRelationalStorage.ECObjectToRelationalStorage.get_ECSchema() at Bentley.Geospatial.ODF.ODFStorageImportCriteria.HasAtLeastOneTemporalSupportedClass(IECSchemaStorage schemaStorage) at Bentley.Geospatial.ODF.ODFStorageImportCriteria..ctor(IImportCriteria importCriteria, String name, IECStorage storage, IECInsertableStorage destinationStorage, Boolean singleClassImport, Boolean registeredConnection, Boolean canModifyData, Boolean lockBeforeModify, String gsKey) at Bentley.Geospatial.DataInterchange.GDIStorageImportCriteria..ctor(IImportCriteria importCriteria, String name, IECStorage storage, IECInsertableStorage destinationStorage, Boolean singleClassImport, Boolean registeredConnection, Boolean canModifyData, Boolean lockBeforeModify, String gsKey) at Bentley.Geospatial.DataInterchange.GDIExplorerStorageNode..ctor(IImportCriteria importCriteria, String name, IECStorage storage, IECInsertableStorage destinationStorage, Boolean allowRemove, Boolean singleClassImport, Boolean allowTopologyFeatures, Boolean canModifyData, Boolean lockBeforeModify, String gsKey) at Bentley.Geospatial.DataInterchange.GDIExplorerImportNode.InvokeNodeOperation(String operation)
The gdb works without problems in ArcGis. The problem is "solved" if I copy the data into a new .gdp in ArcGis, but this is not a desired workaround.
Frank
