HI,
I have problem with Bentley Map.
I have line with text - feature with subfeature. When I modified (move) line text stay in the same place. i must move line next text. Will it be possible that I moved line, the text moved in the same time - together. What Have I to do in my project - bentley map.
We don't know about Bentley Map in depth on this Forum. You'd be better off posting your question to the GeoSpatial Desktop Forum.
Please refer to "XFM Feature Propagation Rules" in Bentley Map help file. It said: "Since a feature can be comprised of one or more component features, XFM uses propagation rules to control how all the pieces are handled during element manipulation. Propagation flags are defined for every XFM sub-feature. The propagation flags can be set to Never, Always, or Lock. If the flag is set to Lock, then the change is propagated only if the MicroStation Graphic Group lock is on. If the flag is set to Always, then the change is always propagated." These flags are define in sub-feature definition by using Geospatial Administrator. I hope that helps. Sebastien Lefrancois [Bentley]
