Along a sewer line are to be compiled servitudes. For this purpose are created for each parcel shapes and those connected to a database. Other shapes on the same parcel concern the temporary occupation. In order to process additional data that I need to find each corresponding shape (shape inside outer shape). Any attempt to solve with a GeoScript spatial analysis (NEAR, NEAREST, INSIDE,OVERLAP) have failed. Either Bentley Map crashes or there are the wrong shapes found.
Does anyone have a solution
Detail:
Geoscript to Test:
*Areas inside a shape (with a tolerance) are searched. DEFINE SCRIPT searchInsideAreas SETUP type Area VALIDATE message "Area size: " area co = 3 numberFound = numberFound + 1 EXPORT numberFound // Save the number END END *Syntax: EXECUTE script INSIDE [tolerance] *Handles all elements that are inside a closed area. If you do not specify a tolerance, the elements must be *completely inside the shape and cannot touch the boundary of the area. *If you specify a tolerance, elements that are inside the closed area can be partly outside the area *but no more than the specified tolerance. * execute innershapes inside 0.00000000001 DEFINE SCRIPT searchShape SETUP file ACTIVE SETUP type AREA VALIDATE numberFound = 0 execute searchInsideAreas OVERLAP TOL If (numberFound > 0) // Check whether any area is found MESSAGE "Number of areas in shape: " numberFound " - Area: " area ELSE MESSAGE "No areas found in shape" END END END TOL= -0.40 MESSAGE "=============================" MESSAGE tol EXECUTE searchShape
Greetings,
What version of Bentley Map is being used? Could provide a copy of the design file depicted above which produces the crash or incorrect results?
Jeff Bielefeld [Bentley]
Export.dgnI have tested with Bentley Map V8 XM - 08.09.04.147 or also Bentley Map Select Series 1 - 08.11.07.113
Attached dgn
Each of those Bentley Map releases are several years old. Using the latest Bentley Map V8i (SELECTseries 4) 08.11.09.713 commercial release your script produces the attached output.
============================= -0.4 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 144.649933 Area size: 144.649933 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 4.134501 Area size: 144.649933 Area size: 4.134501 Area size: 7.940066 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 14.571458 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Area size: 14.571458 Number of areas in shape: 19 - Area: 82.563323 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 7.940066 Area size: 82.563323 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 11 - Area: 9.405288 Area size: 82.563323 Area size: 9.405288 Area size: 31.115489 Area size: 31.115489 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 62.330184 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 62.330184 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 15 - Area: 47.427892 Area size: 47.427892 Area size: 92.332882 Area size: 92.332882 Area size: 31.115489 Area size: 47.427892 Area size: 258.934057 Area size: 62.330184 Area size: 87.427086 Area size: 258.934057 Area size: 62.330184 Area size: 87.427086 Number of areas in shape: 11 - Area: 31.115489 Area size: 92.332882 Area size: 92.332882 Area size: 12.500604 Area size: 258.934057 Area size: 37.453006 Area size: 37.453006 Area size: 258.934057 Number of areas in shape: 7 - Area: 12.500604 Area size: 31.115489 Area size: 12.500604 Area size: 23.185097 Area size: 92.332882 Area size: 23.185097 Area size: 12.500604 Area size: 31.115489 Area size: 258.934057 Area size: 64.553073 Area size: 37.453006 Area size: 62.330184 Area size: 64.553073 Area size: 37.453006 Area size: 258.934057 Area size: 62.330184 Number of areas in shape: 15 - Area: 92.332882 Area size: 92.332882 Area size: 92.332882 Area size: 23.185097 Area size: 258.934057 Area size: 64.553073 Area size: 64.553073 Area size: 258.934057 Number of areas in shape: 7 - Area: 23.185097 Area size: 31.115489 Area size: 12.500604 Area size: 92.332882 Area size: 23.185097 Area size: 23.185097 Area size: 12.500604 Area size: 31.115489 Area size: 258.934057 Area size: 64.553073 Area size: 37.453006 Area size: 62.330184 Area size: 64.553073 Area size: 37.453006 Area size: 258.934057 Area size: 62.330184 Number of areas in shape: 15 - Area: 92.332882 Area size: 92.332882 Area size: 23.185097 Area size: 92.332882 Area size: 258.934057 Area size: 64.553073 Area size: 64.553073 Area size: 258.934057 Number of areas in shape: 7 - Area: 23.185097 Area size: 12.500604 Area size: 92.332882 Area size: 92.332882 Area size: 258.934057 Area size: 37.453006 Area size: 37.453006 Area size: 258.934057 Number of areas in shape: 7 - Area: 12.500604 Area size: 47.427892 Area size: 31.115489 Area size: 92.332882 Area size: 92.332882 Area size: 47.427892 Area size: 258.934057 Area size: 62.330184 Area size: 87.427086 Area size: 258.934057 Area size: 62.330184 Area size: 87.427086 Number of areas in shape: 11 - Area: 31.115489 Area size: 82.563323 Area size: 9.405288 Area size: 47.427892 Area size: 31.115489 Area size: 31.115489 Area size: 9.405288 Area size: 82.563323 Area size: 62.330184 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 62.330184 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 15 - Area: 47.427892 Area size: 82.563323 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 82.563323 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 11 - Area: 9.405288 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 14.571458 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Area size: 14.571458 Number of areas in shape: 19 - Area: 82.563323 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 4.134501 Area size: 144.649933 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 7.940066 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 7.940066 Area size: 144.649933 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 4.134501 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 144.649933 Area size: 31.115489 Area size: 12.500604 Area size: 92.332882 Area size: 23.185097 Area size: 92.332882 Area size: 23.185097 Area size: 12.500604 Area size: 31.115489 Area size: 64.553073 Area size: 37.453006 Area size: 62.330184 Area size: 64.553073 Area size: 37.453006 Area size: 258.934057 Area size: 62.330184 Number of areas in shape: 15 - Area: 258.934057 Area size: 92.332882 Area size: 23.185097 Area size: 92.332882 Area size: 23.185097 Area size: 258.934057 Area size: 64.553073 Area size: 258.934057 Number of areas in shape: 7 - Area: 64.553073 Area size: 12.500604 Area size: 92.332882 Area size: 92.332882 Area size: 12.500604 Area size: 258.934057 Area size: 37.453006 Area size: 258.934057 Number of areas in shape: 7 - Area: 37.453006 Area size: 47.427892 Area size: 31.115489 Area size: 92.332882 Area size: 92.332882 Area size: 31.115489 Area size: 47.427892 Area size: 258.934057 Area size: 87.427086 Area size: 34.913784 Area size: 258.934057 Area size: 62.330184 Area size: 34.913784 Area size: 87.427086 Number of areas in shape: 13 - Area: 62.330184 Area size: 82.563323 Area size: 9.405288 Area size: 47.427892 Area size: 31.115489 Area size: 31.115489 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 62.330184 Area size: 34.913784 Area size: 154.35546 Area size: 62.330184 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 15 - Area: 87.427086 Area size: 82.563323 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 62.330184 Area size: 87.427086 Area size: 154.35546 Area size: 62.330184 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 13 - Area: 34.913784 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 87.427086 Area size: 34.913784 Area size: 14.571458 Area size: 34.913784 Area size: 154.35546 Area size: 87.427086 Area size: 14.571458 Number of areas in shape: 19 - Area: 154.35546 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 154.35546 Area size: 154.35546 Area size: 14.571458 Number of areas in shape: 11 - Area: 14.571458 Area size: 92.332882 Area size: 23.185097 Area size: 92.332882 Area size: 23.185097 Area size: 258.934057 Area size: 64.553073 Area size: 258.934057 Number of areas in shape: 7 - Area: 64.553073 Area size: 12.500604 Area size: 92.332882 Area size: 92.332882 Area size: 12.500604 Area size: 258.934057 Area size: 37.453006 Area size: 258.934057 Number of areas in shape: 7 - Area: 37.453006 Area size: 31.115489 Area size: 12.500604 Area size: 92.332882 Area size: 23.185097 Area size: 92.332882 Area size: 23.185097 Area size: 12.500604 Area size: 31.115489 Area size: 258.934057 Area size: 64.553073 Area size: 37.453006 Area size: 62.330184 Area size: 64.553073 Area size: 37.453006 Area size: 62.330184 Number of areas in shape: 15 - Area: 258.934057 Area size: 47.427892 Area size: 31.115489 Area size: 92.332882 Area size: 92.332882 Area size: 31.115489 Area size: 47.427892 Area size: 258.934057 Area size: 62.330184 Area size: 87.427086 Area size: 34.913784 Area size: 258.934057 Area size: 34.913784 Area size: 87.427086 Number of areas in shape: 13 - Area: 62.330184 Area size: 82.563323 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 62.330184 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 62.330184 Area size: 154.35546 Area size: 87.427086 Number of areas in shape: 13 - Area: 34.913784 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 9.405288 Area size: 47.427892 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 14.571458 Area size: 34.913784 Area size: 87.427086 Area size: 14.571458 Number of areas in shape: 19 - Area: 154.35546 Area size: 82.563323 Area size: 9.405288 Area size: 47.427892 Area size: 31.115489 Area size: 31.115489 Area size: 47.427892 Area size: 9.405288 Area size: 82.563323 Area size: 62.330184 Area size: 87.427086 Area size: 34.913784 Area size: 154.35546 Area size: 62.330184 Area size: 34.913784 Area size: 154.35546 Number of areas in shape: 15 - Area: 87.427086 Area size: 144.649933 Area size: 4.134501 Area size: 82.563323 Area size: 7.940066 Area size: 82.563323 Area size: 7.940066 Area size: 4.134501 Area size: 144.649933 Area size: 154.35546 Area size: 14.571458 Area size: 154.35546 Number of areas in shape: 11 - Area: 14.571458 No areas found in shape Area size: 47.427892 Area size: 9.405288 Area size: 34.913784 Area size: 87.427086 Area size: 154.35546 Number of areas in shape: 5 - Area: 82.563323 Area size: 82.563323 Area size: 9.405288 Area size: 34.913784 Area size: 87.427086 Area size: 31.115489 Area size: 62.330184 Area size: 154.35546 Number of areas in shape: 7 - Area: 47.427892 Area size: 82.563323 Area size: 47.427892 Area size: 34.913784 Area size: 87.427086 Area size: 154.35546 Number of areas in shape: 5 - Area: 9.405288 Area size: 82.563323 Area size: 47.427892 Area size: 9.405288 Area size: 87.427086 Area size: 62.330184 Area size: 154.35546 Number of areas in shape: 6 - Area: 34.913784 Area size: 82.563323 Area size: 47.427892 Area size: 9.405288 Area size: 34.913784 Area size: 31.115489 Area size: 62.330184 Area size: 154.35546 Number of areas in shape: 7 - Area: 87.427086 Area size: 47.427892 Area size: 87.427086 Area size: 62.330184 Area size: 258.934057 Area size: 92.332882 Number of areas in shape: 5 - Area: 31.115489 Area size: 47.427892 Area size: 34.913784 Area size: 87.427086 Area size: 31.115489 Area size: 258.934057 Area size: 92.332882 Number of areas in shape: 6 - Area: 62.330184 No areas found in shape No areas found in shape No areas found in shape No areas found in shape No areas found in shape No areas found in shape No areas found in shape No areas found in shape Area size: 82.563323 Area size: 47.427892 Area size: 9.405288 Area size: 34.913784 Area size: 87.427086 Number of areas in shape: 5 - Area: 154.35546 Area size: 31.115489 Area size: 62.330184 Area size: 37.453006 Area size: 92.332882 Area size: 12.500604 Number of areas in shape: 5 - Area: 258.934057 Area size: 258.934057 Area size: 92.332882 Area size: 12.500604 Number of areas in shape: 3 - Area: 37.453006 Area size: 31.115489 Area size: 62.330184 Area size: 258.934057 Area size: 37.453006 Area size: 12.500604 Number of areas in shape: 5 - Area: 92.332882 Area size: 258.934057 Area size: 37.453006 Area size: 92.332882 Number of areas in shape: 3 - Area: 12.500604
