Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
Geospatial
OpenCities Map
Cancel
OpenCities Map
OpenCities Map Forum
lost subtype when register feature from file geodatabase
Sign In
State
Suggested Answer
Replies
Answers
1 answer
Subscribers
60 subscribers
Views
Users
0 members are here
Offline
ngoc Do Thi Ngoc
over 7 years ago
Hi all,
Have any one can help me with below issue:
I have *.gdb file with Khuchucnangp feature.When I open it by ArcGis, I can see have a domain and
many other subtypes t
hat are relationship with the domain values. But when I register feature, only 1 property and
1 subtype
can be listed. Why and how can I get all the subtypes.
0
Offline
Sebastien Lefrancois
Tue, Aug 9 2016 10:41 AM
in reply to
As gentle reminded, here some limitation of Esri file Geodatabase support in Bentley Map:
Subtypes are supported in that they are registered as a single feature with a domain containing the subtype values. Property based symbology rules can be used to differentiate the subtypes.
Feature data sets are registered as separate features.
Domains are supported only as coded value domains.
Relationships that can be modeled as sub features are supported. However, support is read-only. Features involved in relationships cannot be created, updated, deleted, or exported.
Annotation sub features are not supported in the Esri file geodatabase due to limitations of the API.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
ngoc Do Thi Ngoc
Wed, Aug 10 2016 12:43 PM
in reply to
Thanks all your supports!
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
