Error about setting level in GSA
Hi all,
Have any one can help me with below issue:
I set level for a point cell feature (Khuchucnangp) as image 7.jpg. But when I import the feature from file geodatabase to Bentley map I see that all the map Items are not be set by the level as GSA (level: Khuchucnangp), they get some different levels from created cell(8.jpg). I wish all them in only level that was be set (Khuchucnangp) Do you known how to set it?
(ps: Because of my some cells was be created with some different color parts (9.jpg), and I want to keep the colors as design, so I  must disable "override cell symbology" in GSA)
Parents Reply
  • Hello,
    For sure, as you said, if you uncheck "Override Cell Symbology", none of define symbology in Geospatial administrator will Override native symbology define by Cell model. As workaround, I would suggest to keep this option check and set criteria for color = 0. For Criteria, 0 mean false and it won’t override color defined and use the color from cell. all other symbology will override.
    I hope that helps.
    Sebastien Lefrancois [Bentley]
    This is a test
    Answer Verified By: ngoc Do Thi Ngoc
