Coordinate Transformation
I am a little bit confused about how to apply a helmert transformation.
In the attached file i create two models. The TM3 west model  which has an assigned coord system and the EGSA model which has a different coord system assigned.
Then i attach the TM3 model to the EGSA model and i choose Geographic - Reprojected as orientation.
So as you see in the EGSA model the TM3 model has been transformed to the new coord system.
In the EGSA file i have also with a red color the coords that the TM3 file should finally have.
 So i usally do a helmert transformation between the temp "white coords" and the final "red" coords and i apply it to the temp white geometry.
I thought that if i set the computation helmert parameters in the coord system modifiers of EGSA file will do what i want but it doesn't.
What i am doing wrong?
