I try to export one dgn file to shp but the text (street name, etc) is exported as point and i loose the texty information.
how do I solve the problem?
Hello ,
You will need to fill in a property name manually as yours is Microstation text that's why it does not contain Property type.
And also if property name entered manually for successful export to shapefile , the DGN file must be closed and opened again.
Kindly find the attached video for your reference :
http://screencast.com/t/PPgmBlumH9
Anupama
