Bentley Support/Experts
I have this trouble of posting data, the error says "
Invalid geometry for table_, column OGC_GEOMETRY.13368ORA-13368: simple polygon type has more than one exterior ring" it seems that there is limit of vertices that map could handle because when trying less vertices polygon did not cause any error. Several solutions in the net mentioned to change from polygon to multipolygon to match the the geometry but it still doesn't work. any solution would be very appreciated.
Jun
