Bug in Bentley Map Mobile installation?
I downloaded Bentley Map Mobile for Windows 05.05.01.69, but it seems it cannot be installed. The installer always ended with error, but BMM for Windows Technology Preview 1 was installed at the same tablet without problem.
Based on log files investigation, I discovered Activation Wizard is required to finish installation but is probably not contained in the installation file. After I installed Bentley Navigator CONNECT Edition to the table, Bentley Map Mobile installation runs smoothly.
It creates another question, why Activate Wizard is required if it's presented as free prodcut. I posted it separately.
With regards,
  Jan
