Accessing Point Cloud Tools in Bentley Map - Point Cloud Advanced
 We recently moved from Bentley Descartes V8i to Bentley Map and I'm having trouble finding some of the tools I commonly used in Descartes, I'm hoping these are still available in Map. I work with point clouds and want to have the point cloud advance toolbar. I have opened some of my .pod files I created in Bentley Descartes in Map but the point weight appears very high and I can't find the option to alter this, or the point cloud density. The point cloud advanced toolbar was already available in the tasks window when I first started using Descartes (which was only a few months ago, pretty new to all of this) and I don't know how to add it.  Any help would be appreciated.
Thank you,
 Brandy
Parents Reply
  • Hi Dan and Frank, I checked the version of Map that we had installed and it was not the correct one. We have now installed Map Enterprise v8i select series 4 and the point cloud advanced tools have re-appeared along with other missing menus. However I think I'm still having a problem with it because I am not able to find the map manager. I have looked under file and tools but its not there, there are no icons at the top for it either. I have also tried to create a new file upon opening to see if a new file will have the manager, but I can't seem to do that either, the program just gives me an error message. Any suggestions on what might help?
