We recently moved from Bentley Descartes V8i to Bentley Map and I'm having trouble finding some of the tools I commonly used in Descartes, I'm hoping these are still available in Map. I work with point clouds and want to have the point cloud advance toolbar. I have opened some of my .pod files I created in Bentley Descartes in Map but the point weight appears very high and I can't find the option to alter this, or the point cloud density. The point cloud advanced toolbar was already available in the tasks window when I first started using Descartes (which was only a few months ago, pretty new to all of this) and I don't know how to add it. Any help would be appreciated.
Thank you,
Brandy
Glad to hear that you have the tools again. If Map Manager is missing, it could be due to a conflict in the Installation. Did you completely remove Bentley Map before installing Bentley Map Enterprise? You could try the “repair” option in the Control Panel to see if that will bring it back. Select the product from the list, then the Repair option, as-shown here, then initialize Map Enterprise again and look in the File menu.
Answer Verified By: Brandy Lockhart
