Good evening
I'm newbie on bentley map.I have a heavy DGN that contains several elements text (~ 3000 elements)I want a solution to convert on XFM.
the macro ( text2xfm vba) can convert texts 1 by 1
but for such a number of elements it takes enormously time.
is there a solution to convert all at the same timethank you for helping me on this subject
The original text2xfm VBA sample application could convert multiple text elements to XFM text features using a fence, selection set or the entire design file. If you could upload a copy of the text2xfm.mvba version you are using we can verify whether or not those capabilities still exist.
Jeff Bielefeld [Bentley]
thank you Jeff for your reply .
I want to convert each txt Elements with its own propriety
like that ; after puplishing Dgn in Imodel I will be able to find them on the search bar on bentley map mobile .
if that is impossible. can you help me with another solution
I am using the macro ( text2xfm v1.5) which is below
text2xfm v1.5.zip
my Dgn is like this :
Meskellil.dgn
thank you .
I reviewed the provided text2xfm v1.5 application and it appears the ability to process multiple text elements still exists. If a "Fence" is active when the "Process" button is pressed then all of the text or text node elements in the fence contents matching the selected "Text Feature" setting will be processed. Similarly if a "Selection Set" is active when the "Process" button is pressed then only those selected text or text node elements will be processed. If neither a "Fence" or "Selection Set" is active then pressing the "Process" button will scan the entire design file for all text or text node elements matching the selected "Text Feature" setting.
The "Select Feature" button provides the ability to select a single feature at a time, but it is only used to automatically choose the "Text Feature" setting. This is helpful in cases where you may have 100s of feature classes and scrolling through a large list of available "Text Feature" entries would be tedious.
Check https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/30431/--load-properties-from-text-strings-text2xfm-vba for the latest version of of text2XFM and a PDF readme file.
