Hi.
Running Bentley Map Enterprise SS4 8.11.09.713
In file can partially delete or fully delete individual features without a problem. Can also use fence to delete features with overlap or inside locks on.
When we go to delete using a fence with clip lock on it won't find the features and hence won't delete.
Is this a bug?
Cheers
Alan
Alan, Fence modes "clip" and "void-clip" are not supported with XFM feature in Bentley Map. All other modes, "inside", "overlap", "void" and "void-overlap", will work as expected for the "Delete Fence Contents" tool. Sorry for the inconvenient. Regards, Sebastien Lefrancois [Bentley]
