Label each vertex of a polygon in Bentley Map
I have polygons (irregular) imported into Bentley Map Enterprise using VRT file format with the actual data in CSV format.
The CSV file has a field WKT containing the vertices of each polygon import.
After importing into BME, I would like to label each vertex of the polygon in Map Manager.
How can this be achieved?
SRG
Parents Reply Children
  • Dan,
    I am pasting the WKT value for one record from the CSV file used to import the polygon with a VRT file:
    POLYGON((337329.73 1174781.75,340017.66 1173586.90,339800.39 1173179.64,341130.98 1172473.52,341104.04 1172419.27,342461.65 1171767.54,342488.96 1171713.29,346697.91 1169703.83,343385.55 1162561.90,343357.98 1162561.90,335428.81 1166200.57,336351.58 1167992.86,334532.16 1168807.48,337329.73 1174781.75))
    Is there a PBA expression that I can use to annotate each vertex?
    Tx
    SRG
