H all,
Happy New Year!
I read the geospatial wiki:
Importing ESRI Shapefiles with Topo to their proper elevation
Following the 6 steps, however, in step 4, there is no General section / Elevation row. Please see the situation below:
Any suggestions are really appreciated.
Charley
Answer Verified By: Sebastien Lefrancois
Thanks Dan! Elevation row was found and successfully imported. Please see screenshot below:
Dan,
I faced the same issue as the original poster here. I followed your proposed solution and clicked on the node you suggested. However, that node doesn't list the "Feature Parameters" row either. Please see the attached screenshot. I have verified that the shapefile has an "Elevation" attribute.
Vinod,
Make sure the DGN File that you are using is a 3D file. The Feature Parameters tab will only display in a 3D file.
Thanks for responding to my query. I went back and tried importing the contours into a 3D file this time. However, I couldn't get it to work. The "Feature Parameters" option didn't appear.
