I have a file containing elevation data (contour lines) that are all on the same level. I'd like to be able to select the elements by elevation and change the level attributes. I've tried viewing the data in front and right views, but this is still very time consuming. Any suggestions?
Greetings Turkay,
This type of data manipulation is best done programmatically. If you could provide a sample design file and details on what elevations should be moved to which levels, I would gladly craft a sample VBA application which could be used.
Please feel free to contact me via private message if you are not able to discuss publicly.
Jeff Bielefeld [Bentley]
