Is is possible to read XFM properties / attributes directly in MicroStation without Bentley Map being loaded (or installed). I have been asked to build a tool for MicroStation V8i the recenters the view based on XFM attribute values (a search tool).
I have cross-posted this on the BDN forum.
Cheers Ian
Hi Ian,
No, this is not possible. You will require the XFM engine running inside Bentley Map (or PowerMap) to be able to interpret the XFM properties (and the XFM object hierarchy, for that matter).
So the options you have:
Cheers,
Gijsbert
