Hi experts,
I need help on two questions.
Is there anyway where we can select the updates to be posted (meaning if there are three polygons are digitized in Bentley Map, I want to post only one of them)? There is Apply Where Clause options, however that is suitable for our requirement.
And the second question is, Bentley provides Merge to Parent option, however is there any functionality wherein the changes can be pushed down to the selected version? So this is the other way round, where the child version needs to be updated based on the parent version. We are using Oracle Spatial and Bentley Map Select Series 4.
Appreciate any insight on this.
Thanks in advance,
Kiran.
Answer Verified By: Kiran Gulabrao Bandal
Hi Martin, First thing we wanted to achieve was post only selected changes. That is doable by pre-selecting the updated elements while posting.
And the another thing we wanted was, merge only selected updates with the parent version, although in my original question I had mentioned something different since I was trying to determine the few alternate workflows . Although, it seems Bentley Map does not allow this because after selecting Merge to Parent, all changes in the child are merged with the parent , we had to change our sequence of actions to do this, such as only make those updates which are required in the parent version. And then use Merge To Parent to post to parent. And, if there are some changes, which should not be present in the parent version, perform them after posting. Thanks, Kiran.
