I have 56906 point elements (zero length line) and 56972 text elements in a 2D dgn file.
When I try exporting this dgn to KML format, Bentley Map EnterpriseV8i SS4, the process continuously runs without any end result (output kml file) for several hours.
I am forced to end the process.
The dgn file is 5 MB in size.
I was wondering if there are any known issues with the export to kml, such asof number of elements (count) in dgn file!
Thanks for any response.
SRG
HelloI do not know if there is a primitive limitI can only say in my experience that many textscreate problems that you mentionedmany primitive not.
Ciao
Helloalways in my experiencewhen I save on network servers is interrupted, do not save on serverbut disk C:
