Connecting the MicroStation to a Map Server using an OGC WMS connection and a PKI certificate.
Has anybody got any experience of connecting the MicroStation to a Map Server using an OGC WMS connection and a PKI certificate.  I have tried this with no success and I wondering if it was finger trouble on my part or the fact that the software does not support PKI certificates in this area ?
  • think it should already be supported connecting MicroStation to a Map Server using an OGC WMS connection and a PKI certificate, Can you  try the attached .xwms file and  to  the feature in High security version of MS Connect, and let us know if It works.
    Can you provide us a XWMS that is not working?
    https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5924/2010-Color-7_2D00_county.xwms
