Map mobile raster images
I'm very new to Map. I work in survey. We are trying to implement Map mobile as field tool. Here is my issue:
1. When I publish my i model my export preferences are as shown below:
2. export to my CONNECTED personal share.
3. Open mobile map on Ipad.
I have dgn graphics but no levels or raster images display. What am I doing wrong?
  • Cliff,
    It is good to hear that you've made progress. When creating i-models that contain raster data, a 94mb file size is not unexpected. In fact, depending on the amount of raster and the selected raster image downsampling applied, the i-model could in fact be much larger. Please see the "Bentley Map Mobile Publisher FAQ" page for information on the MS_RASTER_DOWNSAMPLING_PREFSIZE_FORIMODEL configuration variable that can be used to adjust the raster image resolution.
    We've designed Bentley Map Mobile to perform efficiently with multiple gigabyte i-models, containing either 10s of millions vector elements, or high resolution raster data. We have customers using Bentley Map Mobile in production with i-models containing 20+ million features/elements performing efficiently on devices such as Apple iPad minis.
    Jeff Bielefeld [Bentley]
  • Jeff,
    Thanks for the follow up. It does help to know what others are experiencing with Map mobile. The learning curve for the field crews seems pretty short overall. Now I need to learn Map!
    I'll look into the config variable for raster reduction.
    Cliff
