Here is my planned workflow:
1. Publish I-models to Bentley Map mobile (IOS)
2. Survey crew makes redlines on said I-models.
What next? I thought the I-model could be brought back into Microstation as reference file. This doesn't appear to be possible. What can you do with an I-model?
I have a fair amount for time invested in this endeavor to find out the I-model is a dead end. Based on the help files found in SS4 this is or was possible (see capture below):
If I understand this correctly the help files for this topic are NOT accurate. The I-model is a dead end in its self. The life cycle is closed once the file is published via Microstation?
Any ideas?
Cliff
Greetings Cliff,
The workflow is possible using the following steps:
Jeff Bielefeld [Bentley]
Answer Verified By: cliff
Thierry SAGE
TLI Consultant - Bentley Systems France
Please see my comments in this forum post.
