After uploading the markupdb file to my personal share the file isn't visible to the ipad.
Here is what's on the ipad:
Here is my personal share via the portal:
Is it correct to say that markupdb file extensions are not visible to the ipad?
Cliff
Cliff,
You are correct. By design, the .markupdb files which contain the redline data are not visible to the Bentley Map Mobile app. These .markupdb files are intended for use in downstream workflows whereas users can reference attach or open them in a Bentley Map desktop session.
Jeff Bielefeld [Bentley]
Answer Verified By: cliff
