Hi all,
is there a way how to use i-model Transformer (I am complete beginner) when Bentley Map project is converted into Bentley Map Mobile .imodel format?
The problem I have encountered is:
Is there something I missed or is such workflow planned?
It would be nice to be able to enhance published content, e.g. to change IDs to text descriptions more friendly in mobile GUI, after the .imodel is published and not in original project / data.
With regards,
Jan
Jan,
You are correct. During the Bentley Map Mobile Publisher process, a temporary .i.dgn file is created, then converted into .imodel format. The Bentley Map Mobile Converter process does not create an intermediate file, going directly from design file sources to .imodel format.
We have discussed with our i-model Transformer team colleagues a number of potential enhancements that would support a custom Bentley Map Mobile i-model creation process. I believe there are plans to add .imodel input file support to i-model Transformer at some point. The more we hear from users such as yourself on these needs, the more likely we will be able to prioritize that work.
For now, only Bentley Map Mobile Publisher and Bentley Map Mobile Converter are available to create Bentley Map Mobile i-models.
Jeff Bielefeld [Bentley]
Hi Jeff,
thanks a lot for your answer :-)
Unknown said:only Bentley Map Mobile Publisher and Bentley Map Mobile Converter are available
Well ... I know Publisher, as I installed it to the latest Bentley Map and it added File > Publish For Map Mobile item into BM menu. But what is Converter?
Unknown said:I believe there are plans to add .imodel input file support to i-model Transformer at some point.
It would be nice. Regardless I have not many reasons to use Transformer, in particuar situations it's really great tool.
Unknown said:The more we hear from users such as yourself on these needs, the more likely we will be able to prioritize that work.
My current need (fortunately not critical and is logged with low pririty) is:
Because of that, I thought about Transformer to harvest the dictionary and to replace the ID.
I think it can be also an enhancement of Mobile Publisher to be albe to convert not only stored actual data, but to take in account properties, especially how domains are defined (as translation between IDs and their values).
The latest Bentley Map Mobile Publisher 05.05.02.11 commercial release includes the new Bentley Map Mobile Converter, a 64-bit standalone command line tool (MapMobileConverter.exe), that runs from a Windows command shell, does not require use of Bentley Map session and provides extensive configuration capabilities to produce Bentley Map Mobile i-models from both Bentley Map and MicroStation data. It can process 1 or more, even 1,000s of input design files to create a single Bentley Map Mobile i-model.
The Bentley Map Mobile Converter can also detect changes to input design files and generate .changes files that contain changesets which can be used for "Incremental File Updates" in Bentley Map Mobile to ensure field personnel have the latest data w/o requiring reloading of data on mobile devices. All of these capabilities can be used from the command line or from within a ProjectWise i-model Composition Server environment, allowing you to automate and schedule the production of Bentley Map Mobile i-models suited to your organizations requirements.Using XML configuration files, the Bentley Map Mobile Converter provides the ability to control the conversion process for both Bentley Map and MicroStation design files, supporting the following capabilities...
...and more. For MicroStation design files no Bentley Geospatial Administrator schema is required. If you have XFM design file data w/o a Bentley Geospatial Administrator schema the ability to control the Bentley Map Mobile Converter process with a configuration file is fully supported. The Bentley Map Mobile iCS Plugin has also been updated so the production of Bentley Map Mobile i-models in the ProjectWise iCS environment can now use the Bentley Map Mobile Converter process, including the ability to generate and publish changesets (incremental updates). This is important so as the source data changes, incremental updates (e.g. changesets) can easily be generated and distributed to Bentley Map Mobile clients.
You can review the delivered MapMobileConverter.config.xml and MapMobileConverter.config.xsd to get an idea of the configuration capabilities. Using an XML editor such as Visual Studio with IntelliSense can recognize the XSD and provide XML element and attribute documentation. For example, the following is from MapMobileConverter.config.xml which creates Bentley Map Mobile features based upon MicroStation element information.
Here polygons on specific MicroStation levels are assigned a feature class name, category, display priority and symbology overrides.
View thumbnails are defined here...
...variables that can be used throughout the configuration are defined here...
...and referenced here.
There is much more that can be done, but hopefully the above gives you a better idea of the Bentley Map Mobile Converter configuration capabilities.
Please refer to the Bentley Map Mobile Converter documentation for additional information.
Alan,
The process by which the Bentley Map Mobile Converter can be used to generate changesets for distribution to Bentley Map Mobile users can be summarized as follows:
Although the Bentley Map Mobile Converter can be used on the desktop to solve many data production issues, it has been designed for server-side integration with ProjectWise, Bentley i-model Composition Server and Web Services Gateway. Using these Bentley technologies, organizations can create an unattended automated data production and distribution eco-system, keeping all information consumers up-to-date with the latest information.
Please refer to "Western Power Empowers 3,000+ Field Workers with Accurate, Timely Network Maps and Models" and "Western Power Distribution - Electronic Mapping Utility on the iPad" for details of one such organization using Bentley Map Mobile and other Bentley technologies to provide daily updates to 1,000s of distributed information consumers.
