Good afternoon. I have used the redline functions in an i-model with the Bentey Map Mobile app on an iPad. I have no problems selecting the redlines and uploading them to a Projectwise repository. The instructions that I've found state that the redline ".imodel.markupdb" file is then attached to a DGN file in the Bentley Map desktop application.
When I bring up "File > References" and choose to attach, this file format is not available. If I choose "All files (*.*)" and try to attach the redline file, the file does not attach and the Microstation Status bar states that the file "is not a recognized file format."
I am running the Bentley Map Mobile app on an iPad (Version 05.05.02.001) and I am running Bentley Map V8i (SELECTseries 4) Version 08.11.09.836 on MicroStation V8i (SELECTseries 4) Version 08.11.09.867.
Am I doing something wrong or do these specific desktop application versions not support the attachment of redline files back into the DGN environment? My redline file is a 2d file - I did note previous discussions that stated redline of 3d files is not supported at this time.
Joshuah,
The Bentley Map V8i (SELECTseries 4) 08.11.09.836 version noted in your post should provide the ability to reference attach the .markupdb files. You should see the following file type in the "File Open" dialog...
...and the same as seen in the "Attach Reference" dialog:
If you are not seeing these file type selections, please file a Bentley service ticket here so that someone from our technical support team can contact you to diagnose.
Jeff Bielefeld [Bentley]
