How can Bentley Map help me to create Contours, which are further used for Water and Sanitary network modeling?
What are the data/parameters so required for generating contour? I am searching hard for this query on Learn Server and Youtube, but unfortunately unable to get any.
Thank You.
Videet,
Contour capabilities are available in Bentley Map Enterprise, through the Scalable Terrain Model functionality. These tools are located in the Raster Manager dialog box, in the Utilities menu.
Bentley Map does not include the Descartes product and its raster tools, but does interface with other contour-generating capabilities in MicroStation and the civil engineering tools such as OpenRoads.
Here are some additional resources that may be helpful.
Bentley Map Import Contours:
Bentley Map Enterprise:
Descartes:
MicroStation Mesh/Contours:
