After upgrade my Bentley Map to SS4 i have problem with color of attached dgn file. Program is changing layers color from 0 to 7. I can select all layers with color 7 and change it to 0 but when I close attached dgn and open it, colors are still changed to 7.
This issue has been fixed in the Bentley Map V8i Ss4 8.11.9.805 and higher.
See another post talked about it.
I hope that helps.
Sebastien Lefrancois [Bentley]
Answer Verified By: Mateusz Koclęga
