Hi all,
I have a series of ordnance survey data in the UK OS grid and I need to convert them to UK SnakeGrid. Is this possible within microstation? if so can someone illustrate to me how
thank you
Hi Nelson,
Just to clarify this point - the EnglandHighway* GCS grids are defined in the IAN99 standard and none of these are Snake Projections.
There are approx 60 SnakeGrid systems defined in total - however the only SnakeGrid currently available in Microstation (CE update 14) is the HS2 Rail SnakeGrid (HS2_Snake_2015; HS2_Snake_2002).
Brgds, Jim
