I have survey data to make a map of a place, by which I made a map. I have to set coordinate on the basis of our local coordinate value. I have also to set grid line in my map.But I can’t able set grid line in my map.Is it possible to set grid in Bentley map? some one please help my.
Have you looked at the Grids & Graticules options available in Bentley Map?
The parameters are described in the Bentley Map Help document.
Grids can be placed using the Active Coordinate System, or an Alternate system:
Is there any video tutorial for grids and graticules..whether its similar like in ArcGIS.. i have experience in ArcGIS ..which version of Bentley map support this feature..any trail version is available for this feature
