We use the databrowser a lot for editing the same property on all selected features. However we often experiences that the edit option is missing in the right click menu. Some times it helps to scroll down to the bottom of the feature list, but not always - does anyone have an idea what's wrong?
Some (or All) of selected cell are probably read-only. If only one of selected cells is read-only, it wont display the edit option in the contextual menu. A read-only cell could result from a element locked, read-only, referenced, etc. If you updated the status of elements to allow user to edit it, you will need to reload data in data browser. This is not a live status updated.
I hope that helps.
Sebastien
Hi Sebastian
I have noticed that, but even if all the selected cells are editable, we experience the problem. As fare as i can tell, it happens when the list of features is so long, that we have to scroll up and down in the browser window. If the edit option don't show in the contextual menu, we have to scroll up and down until edit option for som reason appears in the menu.
Hi Peter Norvin.
Sorry for late reply.
The unwanted behavior you described has been reported to our team last winter and it has been fixed in the update 6 version of Bentley Map V8i Ss4 and further releases.
Sorry for the inconvenient.
Answer Verified By: Peter Norvin
