I am attempting to open an LAS file into Bentley Map V8i. Any ideas why LAS to POD file would fail in Bentley Map? I am able to open some LAS files, but another group in a different geographic location won't even attempt to load. I automatically get the "Convert Failed" message when attempting to 'Attach' it.
The LAS files are ~25,000,000 points.
Thanks in advance.
I was wondering if anything has come from this. I'm still getting convert failed (no reason). I'm using aerial Lidar from a vendor and I'm not sure how to check the version or how to change the version. Any help would be appreciated.
Thanks.
Hey Anthony, you can run LASinfo on your point cloud to find what version it is. https://rapidlasso.com/lastools/lasinfo/
Bentley Map seems to only convert from LAS version 1.2 so use LASinfo to check that.
I have no idea how to use this. Is there a download button?
Actually I'm using contextcapture editor for this no BM. Still getting convert failed though.
