In latest Map/PowerCivil version when exporting to SHP there is now "Error: Duplicate property name: asq_lasted. Previously in it exported without issues. As I understand it is because of 10 character attribute name limit for SHP files but we don't have such property in database as asq_lasted. Is it hardcoded?
Hi Oto,
I understand you are receiving Duplicate Property Name message when trying to export to shapefile.
I would like to know which version of Bentley Map you are using, and also if you could provide us with the dataset we can investigate further.
Meanwhile, you can refer the following community article:
https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/27042/why-do-i-get-an-error-duplicate-property-name-message
Thanks and Regards,
Komal
It is version 08.11.09.878
I will make a small dataset.
